Re: Oil Injection Removal 1995 Merc XRI 150
I have a 1997 SportJet 175xr2 in a Sugar Sand Tango purchased off an open storage facility, on blocks 2 yrs. A prior owner had totally removed the remote oil tank and all hoses to include the cap on the engine tank. I was told he ran pre-mix in the main gas tank, bypassing the injector system. I did not know if this was practical, long term, so thought to buy a used remote tank system replacement. Your post makes me think the original problem may also be the oil pump gear. How can I test or verify that? Is it a sight inspection with a bright penlight after removing the oil pump? If a stripped gear is found, that is a deep engine repair, right? Therefore I should forget the oil tank system rebuild and just premix forever? What are the long term effects, if any? (other than the gum likely blocking the carbs and in the 1/2 full tank of 2 year old gas that will be h... to pump out and clean). If all gas goes 10% ethanol, will the marine additives to combat the ethanol be diminished by the oil? Anything will be helpful.
Greybeard51
