  #1
Old May 5th, 2009, 12:01 AM
darcyro darcyro is offline
Default Mercury 40HP 4 CYL Cooling Issues?
Hi All:
Title gives particulars for this 1990 2 stroke motor. This motor is new to me, and was purchased last fall and hasn't seen the water this spring. While preparing to put it in, put on the ear muffs and turned on the water. Nothing comes out anywhere. When run (briefly) same thing, nothing comes out anywhere. Still waiting for the facrtory service manual, but have some questions before it arrives:
Where are the water exits for this model? Does it have a thermostat? Appears it might have two water pumps. Is this so?
Thanks for any insight!
  #2
Old May 5th, 2009, 12:11 AM
mark_gober mark_gober is offline
Default Re: Mercury 40HP 4 CYL Cooling Issues?
I'm confused. It's a 4 cylinder that only puts out 40hp? I'm going to go out on a limb and say that it probably does not have a thermostat. With it only being a 40hp, I'd guess that it only has an impeller and that it would be pumping at all times when the engine is running. (this is only speculation because I'm not sure of your model) Perhaps you can provide a little more information.
Mark
  #3
Old May 5th, 2009, 12:45 AM
dpal's Avatar
dpal dpal is offline
If it is the same as my 93 40 hp, a stream of water should come from a small hole just to the right of the motor cover release as you look toward the front of the boat. Mine has a black rubber tube that connects at the top of the motor close to the top spark plug and runs down the right side of the cylinders to the aforementioned hole. Mud daubers (insects) like to build in these tubes and clog them completely. Remove the tube and make sure it is clear. Mine takes about 10-15 seconds at idle to start streaming water from the hole.
  #4
Old May 5th, 2009, 10:52 PM
Yeah it really is a 4 cyl with 40hp. I'm familiar with an Evinrude of about the same vintage and thought I knew what to look for. I've let it idle for at least a minute, but no water. I can' find the rubber outlet tube at all. I'll know a whole lot more when I drop the lower unit and inspect the water pump. Then I'll know if the seller was honorable. Thanks for the comments.
  #5
Old May 22nd, 2009, 09:48 PM
Follow up to my original post/question: The water outlet was plugged up and it looked like a tiny air filter. It was right in front of me. Replacement of the water pump was very straightforward, but two people made installing the housing over the new impeller MUCH easier. Next time I'll install the impeller without the upper gasket in place, remove the housing with the impeller still inside the housing and then place the final gasket on the metal piece. The gasket won't rip that way... Old impeller was very tired. Water now comes out like it's a healthy horse!
  #6
Old May 23rd, 2009, 07:28 PM
JT36 JT36 is offline
Hey darcyo, I've got the same 40 hp merc and am going to attempt to change water pump also. Only difference is I'm new to boat motors and would appreciate any suggestions that you might have. I, like you located the tube that goes to the weep hole and disconected it there. After clearing tube of mud I then tried to get water to move thru system while motor was at idle for a minute or 2. No luck. I then blew thru the tube and air freely came out of the water intake area where you put the earmuffs on to run water thru engine. I guess like you it's time for water pump.
any suggestions???
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1974 65 HP 3 cyl cooling issues cheapthrills Mercury & Mariner Outboards 4 December 16th, 2008 08:54 AM
1982 40hp mercury 2 cyl. no fire need help bigg20032000 Mercury & Mariner Outboards 12 September 15th, 2008 09:42 PM
1989 Yamaha 40hp 2 stroke 3 cyl CDI issues... SuB8HaVeN Yamaha & Suzuki Outboards 12 January 13th, 2008 06:28 PM
Mercury 40hp Jet starting issues czak Mercury & Mariner Outboards 0 July 10th, 2007 03:34 PM
1980 Mercury 7.5 Cooling Circuit Issues lake112 Mercury & Mariner Outboards 1 March 9th, 2007 10:21 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
