bassfisher80
- Apr 5, 2009
- 2
I have a 1972 Evinrude 100 HP with electric shift. I took it out for the first time yesterday and discovered I have no neutral or reverse. I can engage the neutral button and the control and the motor will start. The previous owner said this happens "sometimes" but will switch into neutral after a few tries. I also found out he was running standard gear oil in the lower unit for at least 1 season. I have already drained the old oil and replaced with premium blend (prior to my boat ride). I don't know much about how this electric shift works, but is it possible that the parts are still just gunked up with the old oil and will start to work with a little bit of time? Otherwise, any suggestions on how to diagnose and correct?
Thank you.
Thank you.
