fishinfill1
- Mar 17, 2009
- 7
Hi there,
I just purchased a seadoo about 5 weeks ago, This is my second time with it on the water and it seems to run great. The only problem with it is the temperature sensor. I was running it on the water today (relatively easy) when the overheating signal came on and it displayed H-TEMP., With the long beep etc. So i then looked to see how hot it was and it said 57 degrees. I then sat in the water with the seat off for about 20 minutes. After that i started it up and headed back to the dock and there was no overheating, so i looked to see the engine temp. and it said 63? so it increased by 6 degrees and the warning was still off? Does anyone know what the correct temperature should be between, Or have any knowledge/experience with this?
Thanks,
Michael
Thanks,
Michael
