  #1
Old May 3rd, 2009, 10:30 PM
brplut40 brplut40 is offline
Default Tower installation position
I have a 1993 Sea Ray 200 Bow Rider. It is a 20' boat and I already purchased the DIY Wake Pro Universal Swoop Tower. I am going to install the tower soon, but had a few questions firsts. The directions state the rear mount must be positioned behind the rear of the windshield in order to collapse the tower. I may just have a really long windshield, but the rear of the windshield is roughly 5.5ft from the rear of the boat. The directions say to space the feet 38-44 inches apart based on how much you want it to slope. I am worried that the tower will be mounted to far back on the boat. I know the ski pylon must be centered left to right, but is there any advice for how far front or back the tower should be mounted? I just want to make sure that the tower and boat are not stressed due to being too far back on the boat.
My second question is if anyone has this tower, exactly how does it fold down? The directions say to loosen the rear bolts and remove the front bolts. If this is all you do, wouldn't the front legs stick up in the air when the tower is folded down?
  #2
Old May 4th, 2009, 02:08 AM
kyle f kyle f is offline
Default Re: Tower installation position
You want to try to center the pylon on the lenght of the boat from tip to tail. Or, as close as possible. This gives you the most stability when the rider is pulling on it to keep from pulling the boat off a straight line.
The stresses in the legs will actually be a bit higher a this poing because the boat will not be as incline to move and this must absorb the force, but that is th epoint of gettign the tow point in the center of the boat. Same reason slalom ski boats have thier pole in the middle of the boat.
Make sure to re-inforce the mounting points.
__________________
07 MB Sports B52 V23
2000 F250 Powerstroke Diesel with Banks Stuff and Lift
84 Bronco 302/C6... Toy
  #3
Old May 5th, 2009, 01:25 PM
brian_mcwhirter brian_mcwhirter is offline
I just bought the same tower and installed it last weekend. Haven't had a chance to use it yet, but I'm itching. . .
Anyway, I don't think it makes a huge difference how far back the tower is mounted. I would think, the further forward it is, the easier the boat will plane because of the angle of tension on the rope (that's my 9th grade physics kicking in). On the same hand, with it further back, you may get a slightly larger wake which is what you're looking for anyway, right?
As far as folding, it's pretty cleverly designed so that when you take the two allen screws out of the top piece (the one with the tow point), the front legs fold down, so it actually folds very flat, very fast.
Have fun!
  #4
Old May 5th, 2009, 04:31 PM
smokingcrater smokingcrater is offline
**deleted**
  #5
Old May 6th, 2009, 11:29 AM
Bla, sometimes I forget I/O Vs. Inboard.
Above post is correct. Your Draft will affect your best position as not all of your hull will be in the Water, plus you don't have any stabilizing fins under your hull. You need to determine where you Chine breaks out of the water and have you to point middle (if possible) between that line and the tail of your out drive.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Who needs a Tower. Serria1 Wakeboarding 10 August 14th, 2008 04:12 PM
DIY tower installation....any pointers?? TonyNoriega Boat Topics and Questions (not engine topics) 1 August 22nd, 2007 09:49 AM
ignition switches - four position to a three position? glostah Johnson & Evinrude Outboards 14 June 5th, 2007 07:15 PM
ujoint position on o/d installation crazy charlie Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 April 13th, 2005 09:01 AM
Tower DAG Boat Topics and Questions (not engine topics) 7 February 13th, 2005 09:44 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
