  #1
Old May 3rd, 2009, 06:08 PM
Aluma-Bass Aluma-Bass is offline
Default 1982 4.5hp Evinrude cooling & seal quesitons
Ok so i just replaced my impeller bc my motor wasnt spittin out water like i thought it should be. Before i changed it at a idle it would spit water sometimes and then stop for 15-20sec and spit water again. So i changed impeller and took it out for test run and as long as im giving it throttle it will stream water out but when i go slower speeds/idle it seems to be intermittin spitting out water and believe motor heats up so i shut it off. I run it WOT and cycles water fine? I checked for blocks in water intake on lowerend and nothin it was clean. Anything else i can check or replace to make it cycle water constantly even at idle? replace water pump?
Next question is i am gettin some water into my lowerend oil so i know i must have seal leak. How do i know what seal to replace and what possible seals could be leaking?
4.5hp EVINRUDE 1982?
E0015080
MODEL - E5RHCNR
  #2
Old May 3rd, 2009, 06:31 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1982 4.5hp Evinrude cooling & seal quesitons
pressure test the lower unit to find leak, impeller sounds fine. at idle you only get a mist or droplets.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old May 3rd, 2009, 06:38 PM
how would i pressure test lower unit?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1982 evinrude 15 cooling suthernoutlaw Johnson & Evinrude Outboards 13 March 4th, 2009 09:11 PM
Evinrude 1982 7.5hp mimo Johnson & Evinrude Outboards 2 May 25th, 2008 09:02 PM
9.9 Evinrude outboard quesitons wheresthefish Johnson & Evinrude Outboards 2 April 6th, 2007 10:21 PM
1982 Evinrude Cooling Problem Brackishbob Johnson & Evinrude Outboards 4 January 28th, 2006 02:44 AM
Removing the geabox - 7.5hp 1982 evinrude - help! CraigHendo Johnson & Evinrude Outboards 5 January 9th, 2006 02:33 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
