On a 2002 3.1L Yamaha VMAX. Is it typical for the trim shafts to become mushroomed on the ends? Mine appear to have been worn that way during use. I was planning on just replacing the seals, but I cannot get the cap to slide off the end of the trim shafts due to the enlarged diameter. I could file the edges down. But when I raise and lower the motor, I can see where one side of the trim arm is closer to the outer edge of the seal than the other (off center)...indicating the trim arm is either bent or the tilt/trim assembly is not as free to rotate as it should be. So, I'm thinking if I have to replace the trim arm, why file down the one I've got. I cannot purchase just the piston from boats.net and don't know of any other suppliers. Another question for those who've worked on these. How often should the ends where the trim pistons contact the motor bracket be changed? I suppose if I change the pistons, I should change the stops too...thoughts?
Thanks for any inputs.
