chewie1997
- Oct 9, 2008
- 41
Which according to the model (e35rcnd) it is a 1982 35 hp not a 1984. I Paid $350 for it. The prop is a little beat and could use a replacement. the plug boots look worn and probably should be replaced. I did start it. The pull is jerky. Sometimes I can get full extension out of the rip cord and other times not. Is there an adjustment I can make to smooth this out?
Also, there is a hole where I believe there should be a pee stream. there is nothing there. any ideas? Where is the best place to buy replacement plug wires and a prop? thanks! hope the motor was a good buy...
