Motor swap
mdcwells
I am going to put a 1984 Johnson 50 hp on boat in place of a 1987 Johnson 48 spl that has low compression on top cylinder. Will the electrical stuff plug in the same way? It looks like I'm going to have to wire battery ground, 12 v to starter and a plug. I noticed that OMC changed a lot of the ignition stuff in 1985. Is this a tricky swap? It does not look to bad.
rickdb1boat
Re: Motor swap
Yes, it will match up. Big red plug, battery negative to engine block and battery positive to starter.
tashasdaddy
Re: Motor swap
Positive cable goes to the solenoid, not to starter.
mdcwells
Re: Motor swap
Thanks, you guys seem to keep me on the water. It looks like the tilt and trim I have should bolt right on the 50hp as well. The 50 has a pretty nasty skeg and lower unit. Looking at part numbers it wold seem I could throw the lower unit off the 48hp on the 50hp. Would you agree?
mdcwells
Re: Motor swap
Thanks for the link and the diagram TD. They do seem to look nearly identical but they have different part numbers. There is only one way to find out. As they say here in central Iowa hold my beer and watch this!
