The rubber boot on the shift rod has water in it, there is a cable tie on the lower part of the boot. Is there suppose to be a cable tie or clamp on the upper part of the boot where the rod goes thru ? Last year the mechanic said he found the boot unattatched so he re attatched it. Lower unit still has water in it. Thanks for advice.
