  #1
Old May 1st, 2009, 11:45 PM
Wyomingman Wyomingman is offline
Default 2002 Yamaha 4-stroke 15hp fuel filter
I have a 2002 Yamaha 15hp 4-stroke that I had out for the first time this year and it ran for about 3 minutes and died. I replaced the fuel filter although it was not the same one. I do not have a marine shop close by so I bought a Fram fuel filter at a local auto parts store. It looks a bit different as it is clear and you can see the filter inside opposed to the one I took off the was skinnier and white. I also changed the spark plugs.
I still cannot get the motor to start. I am unsure about the fuel filter I put on as it only fills up about 1/2 inside.
Any thoughts on this or other problem shooting to get this motor started???
  #2
Old May 2nd, 2009, 11:22 AM
cousinabe's Avatar
cousinabe cousinabe is offline
Default Re: 2002 Yamaha 4-stroke 15hp fuel filter
I am guessing at some things cause you didn't post your full model number off the port bracket.
sure sounds like you have a gummed up carb. did you stabilize the fuel and run it through the engine prior to letting the motor sit all those months?
please provide a little history.
the fuel strainer, part #5
http://www.boats.net/parts/search/Ya...201/parts.html
to clean the carbs, take off the float chamber #2, and clean up inside there including the needle valve, main and pilot jets. I use CRC 0604 or tech 2000 from walmart, use safty glasses and skin protection.
http://www.boats.net/parts/search/Ya...TOR/parts.html
if you don't run the motor on a regular basis, add stabilizer to the fuel, either startron or stabil(the Marine/E10 formula)
  #3
Old May 2nd, 2009, 11:56 AM
I just bought the boat used about a month ago, so I am not sure about winterization. Previous owner did sa he did though but who knows.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2002 15HP 4 Stroke $950 good deal? dbear1959 Mercury & Mariner Outboards 1 February 27th, 2009 09:33 PM
2002 15hp 4 stroke (odd oil issue?) hendu3270 Yamaha & Suzuki Outboards 2 October 9th, 2008 05:17 PM
2002 Yamaha 15hp 4 stroke sputtering... hendu3270 Yamaha & Suzuki Outboards 6 August 11th, 2008 10:27 AM
2002 Yamaha 15HP 2 stroke carb mystery? old boat NC Yamaha & Suzuki Outboards 4 July 8th, 2008 07:59 AM
2002 yamaha 15hp 2 stroke help needed rosscopeeko Yamaha & Suzuki Outboards 2 November 25th, 2006 05:27 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
