Re: 1996 150hp has trouble starting, runs rough
Its an injector solenoid instead of the older choke though right?
Is the red lever correctly set along the length of the solenoid?
Can you hear it click when its keyed?
You need to "gap test" the ignition, a sparkplug against the cylinder head just doesn't do it, under the compression there is a lot more resistance for the spark to jump the gap, autozone sells gap testers for less than $12, set it to 7/16th inch gap or 3/8ths and look for bright blue crack.!
If you get a yellow spark, its weak.
Also be sure to use the correct champion plugs.
Mine runs rough until it starts to warm up a bit, I keep bumping the solenoid for the first 30 seconds to keep it going, then slightly raise the idle and its good for the day.
Everyone develops their own start proceedure, I bump the key 3 times to inject some fuel then crank it , if it fires I push the key in again and it will start running. Worked almost every time so far.
