Re: Slow Cranking on 1989 Force 85 HP
Well, if you are jumping it at the battery terminals and it is cranking fast and starting, you have eliminated the starter, the cables, and the connections.
THUS: It MUST be the battery! It does not have the voltage potential to crank the starter.
See if it is being charged. Use a VOM and check the voltage rectifier OR with the engine running see if voltage to the battery is about 14. Less than 13 and you are not charging the battery. This could be a bad rectifier or a bad stator. A bad stator will have infinite resistance with the wires disconnected from the rectifier. Normal resistance is about 1/2 to 1 ohm.
With all wires disconnected a GOOD rectifier will show continuity between the A/C terminals in one direction AND continuity in one direction only on the plus and minus terminals and the A/C terminals. I forget the exact test sequence but it is in almost any manual.
If you are charging properly: Since both batteries were new, it is time to check for a current drain somewhere in the system--not only the engine, but the boat as well. Are the gauges wired incorrectly so that they stay on when the engine is not running? Automatic bilge pump constantly running? Radio left on? ETC.
