2007 DF 140 cooling problems
csleona
No pee, I've checked the impeller but it seems fine. I have also hooked to a water hose and it pees under pressure, and also pushed water back through the pee hole thinking that i may have a clog but that didnt help either. Any suggestions?
reeldutch
Re: 2007 DF 140 cooling problems
did you drop the lu and put a hose on the watertube and than it startet to pee?
if thats the case you have defenatly a waterpump problem.
when you run it does it overheat?
take the tstat of and see if water flows there.
Silvertip
You cannot tell the condition of the water pump impeller by looking at it. Should have replaced it as long as you were in there. Forcing water through the system is not an indication of anything. Does the tell tale flow with the engine in the water?
cousinabe
as Silvertip stated, impellers look good even when they are bad.
csleona
Will part # 18-3258 work on this 2007 ? What is the tell tale? There was no flow in the water that I noticed.
