Quote:
Originally Posted by Crisco87
The outdrive is an OMC but I am unsure as to what model it is,
800 Series - as it says on top of it - also looks like it says 1.50:1 which is the gear ratio for a 350/5.7L V8 application
The lower unit pictured is a full mechanical shift type which was introduced around 1981/82, so between that point, and the V6 logo, there has been some newer used parts added.
Have you operated the boat? My first question would be "how hard was it to shift to neutral?"...but we can cover that issue later
My guess would be that a lower unit was swapped from a V6 boat. If that is the case and the upper gearbox was reused, the drive is still the same 1.50:1 ratio which would be important for performance
V6 and V8's used the same gear ratio in the lower.
If you see anything that may need repaired please let me know.
1. non-marine fuel filter before the carb- unsafe
2. distributor does not look like a marine unit - again a safety issue
3. There's an automotive EGR valve on the intake- not a marine part - makes me suspect someone swapped an automotive engine in.-not necessarily cause for panic, but ignition and fuel parts need verifying for marine compatibility to make the boat safe.
check the starter to make sure it is marine (Look for "SAEJ1171" on starter, alternator and distributor for marine spark arresting certification)
4. Google the carb part numbers to see if it is a marine part
If the engine is a V8, then why does the outdrive say V6?
Again, some parts swapping evident...The part that has the V6 stickers on it is the exhaust housing of the drive.
Either your boat has been repowered with a bigger engine, or at least some parts of your outdrive are off of a boat with a V6.
Again, the lower units of the V6 and V8 are identical but for that decal on the exhaust housing, but the upper unit gearing will be different ratio between a V6 and a V8.
There should be a tin tag on the upper gearbox starboard side with a drive model number on it - 6 or 7 digits starting with a "9"
Ebay is a good place to look for OEM manuals.
I would recommend a manual for 1982/83/84 or 85 so you have info on the lower unit pictured.
