Any way to adjust timming without tools
199675hpforce
I have no test light, last year i adjusted the idle up with some screw. It still shakes little bit stalls out but runs ok all out.
Barnacle_Bill
Re: Any way to adjust timming without tools
You need to do a link & sync according to your manual. Timing is just one of the steps. You can rent a timing light at your local auto parts store.
Frank Acampora
OOOOOH! Would you mess with your car without the proper tools? Would you try to repair your house without tools? Would you want the aircraft mechanic of the airliner you ride in to treat it the way you treated your outboard?
Think about it this way: A timing light will cost less than 30 bucks and a manual about the same. So for the price of gas for one weekend, you will know what you are doing and use the proper tools.--A VERY INEXPENSIVE INVESTMENT considering the considerable damage you can do to the engine without them.
puddle jumper
One more recommendation get a manual. You would be surprised how easy it is to fix it correctly.
199675hpforce
i have a manual, there's only one carb
so nothing really to sinc. Problem with manual it goes over every outboard lol i hate that. Just looking for correct way to get her running good. Top cyl seems to be lower comp than other. Its within specs last time i checked five years ago. Ive got it close now but think turning the timing screw might be good idea? If frank lived closed id offer some beers lol he rebuilt his. Will any timing light work? I could get a rental at autozone.
