RodFlicker
- Mar 30, 2009
- 1
I have a '96 mercury 115. This motor was recently purchased and I have not had it out on the water yet. It starts and runs well and has great compression. One problem I have noticed is that the motor seems to leak fuel after it is turned off. The fuel seems to be dripping out of the carburetors and collecting in the motor housing. I am thinking this is simply unburned fuel that is left in the carbs when the motor is turned off. It is probably only an ounce or two of fuel. It's just a pain because it drips into the back of the boat and down the motor so it needs to be cleaned all the time. First, is this little bit of extra fuel in the carbs normal? Second, if so, is there anything I can do to keep this from getting all over the boat all the time?
