Re: how to test a coil??
have pulled wire from coil off of dist cap and there is no fire from coil to cap.so would that not mean you would have no fire from points if there is no fire from coil.
Ayuh,...
Point fired ignition 101,...
The Coil has 3 wires,...
The (+) which is the 9V or 12V Primary side...
The (-) which is the negative Primary side...
And the High-tension lead to the distributer cap center...
The (-) Negative side of the coil is wired to the Points, located in the lower section of the distributer...
When the points Close,.....
The Coil is Grounded on it's primary side,... Which fires the 2ndary side, aka. the High Tension lead...
Which of course goes to the top of the distributer, to whichever sparkplug is firing...
I think you're confusing the Primary,+ Secondary sides of the system...
The Points fire the Coil....
Did you download the Manual for it yet,..??
