Mercruiser 140 miss under load
Ched23
I have a mid 80's mercruiser 140. The engine free revs fine and idles ok, but under load backfires out the carb. This only happens running in the forward direction. In reverse this doesn't happen. We have trouble-shot the entire ignition system one piece at a time and this is still occurring. Both fuel filters have been replaced with new units and the carb has been disassembled and cleaned and appears to be functioning correctly. The fuel in the tank is new. The timing is set to 6* BTC at idle. There also seems to be a lot of "blow by" coming out of the PCV valve. What items should we be looking at to trouble shoot this problem?
Don S
Re: Mercruiser 140 miss under load
Do a proper compression test, then a full tuneup, including setting the dwell, timing and advance timing, change all the fuel fiters and check for water and contamination in the fuel. Then post back with your findings.
