Re: shifter stuck in forward 1967 6hp evinrude fisherman
Hold on, you don't have to remove the powerhead on about 1965-up. There is a shift rod disconnect in the gap when you lower the gearcase about 3/4"
However, to get it down that far, the seal drive pin in the drive shaft has to align with a slot. Revove the spark plugs, then slowly rotate flywheel till pin aligns with slot and gearcase drops down. Then disconnect shift rod and remove gearcase. Note the position of the pin so you can put it back the same way for ease of reinstallation. And don't turn the flywheel while the gearcase is off. Doing that, it will slide right up into place.
You do NOT have to remove the pin from the shaft to get the pump off. Merely pull the shaft out of the gearcase. It will slide right back in.
