  #1
Old April 29th, 2009, 04:59 PM
fish2287 fish2287 is offline
Default 1996 Mariner Outboard 115 HP oil Injected 2 stroke blown??
I ran it out of oil (low oil beeper never went off) and I'm getting a major ticking noise, still seems to run good excepct for the anoying tick.
I keep getting differnt advice from repair men. One says he can tear it down replace all four cyliners, pistons and rings for about $2200 parts a labor. The other says you cant repair an engine that was run out of oil you better to buy a new or used engine and another says why fix it all jusy fix the bad piston?????
What should be done? They all have me so confused[/size]
  #2
Old April 29th, 2009, 06:37 PM
CharlieB CharlieB is offline
Default Re: 1996 Mariner Outboard 115 HP oil Injected 2 stroke blown??
Most ANY engine can be repaired, at a cost.
What cost?
That all depends on the damage found once it is taken totally apart and every internal part inspected and mic'd.
You COULD get very lucky and get by with ONE piston, new rings on ALL pistons, plus gaskets and seals.
Then again, the crank could be scarred, rods egged out, all bearings roasted, all cyl's and pistons scored. Worst case, a re-manufactured or new engine COULD be cheaper AND carry a warranty.
Until it is taken apart, it is only an educated guess.
Many of us are pretty good, d&%# near the best, but we are NOT psychic, and have to look at EVERY part before we can give you an accurate cost to repair.
You could learn to do the job yourself, at least then you could save the cost of most of the labor.
Just keep posting your questions here and we will try to assist you.
  #3
Old April 29th, 2009, 06:50 PM
sportsmanphil sportsmanphil is offline
You could run a compression test, a leak down test and even set a dial micrometer on the piston through the plug hole and on the flywheel to see if there is movement between the crank and pistons.
Problem is, these require special tools and a bit more than basic knowledge, which may frustrate you more than help. But it could let you know if the crank/bearings and wrist pin/rod are fine and its just a ring and hone job.
If you must hire someone for these tests, it might cost you just as much to have it torn down.
Hate to hear of your bad fortune, good luck with it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Suzuki 115 2 stroke oil injected 1996 rev limiter problem Submoa Yamaha & Suzuki Outboards 7 May 6th, 2009 07:30 PM
1994 115 oil injected two stroke problem tglee Mercury & Mariner Outboards 2 March 1st, 2009 09:51 PM
1996 Mariner 115 HP Outboard trim won't go down from Throttle Switch fish2287 Mercury & Mariner Outboards 1 June 12th, 2008 05:58 PM
1988 Mariner 50 HP 2-stroke oil injected judyglen Mercury & Mariner Outboards 17 August 26th, 2005 05:58 AM
1996 Johnson 115 Oil injected - Full Power? jallen911 Non-Repair Outboard Discussions 2 July 10th, 2005 10:32 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
