I have a 1960 18 hp Model FD-14 and am having some issues. The motor starts fine in 2 pulls and will idle for about 20 seconds then die. If you pump the primer bulb it will stay running. If you start to open the throttle it just sounds as if its bogging down untill you pump the primer bulb. Has absolutely no WOT capabilities even if the bulb is pumped. Carb has been rebuilt, getting great spark, fresh gas, new plugs, new fuel line connectors, running outta possabilities here thats it. Thanks guys.
