bob johnson
- Feb 25, 2009
- 4,304
so have this motor of mine torn apart all the way down to removing the tilt -trim unit and splitting the mount bracket...now I have the main body that houses the Pivot for the motor for turning and for the the motor tilting...
the tstainless steel tube that runs through this part , that the steering cable goes through, needs to come out now...or at least i want to take it out to replace the bushing..I melted one slightly when I had to heat one of the halves on one side to remove it.
there are two holes that go through the casting, that look like they might have been set screws...it is hard to tell...is the tube press fitted in??
thanks
bob
thanks
bob
