Ok guys, New to the sight here and first time boat owner, Inherited a 84 wellcraft 210 elite. One issue that i am having is that when i turn the key the what i believe is the ignition solenoid clicks but nothing was turning at the starter so i had replaced the starter and then when the key turned the starter would engage but not turn the motor almost as if the bendix was not engaging, I removed the starter to make sure that there werent any more issues that i had not seen and everything looked good. I reinstalled the starter and once again turned the key only to once again getting that solenoid popping but nothing working back at the starter. all contacts have been cleaned and the cable coming from the battery has been replaced along with the battery itself... any ideas?
