  #1
Old April 29th, 2009, 11:23 AM
fmmo fmmo is offline
Default yamaha f225 cuts out after run
since last year after rides, 1/3 of the time motor cuts out when shift gear to neutral, turn key starts right away. my normal RPM is 600. usually after short ride is fine but i would say after hard run it cuts out more often. water pump replaced last season, spark plugs, filters been changed during spring prep. what's wrong with it? oh! almost forgot it has 350hrs. thanks in advance!!!
  #2
Old April 29th, 2009, 12:50 PM
cousinabe's Avatar
cousinabe cousinabe is offline
Default Re: yamaha f225 cuts out after run
If your engine is NOT coughing/sneezing and stalling because of a low idle, your problem could be related to bad tstat, ISC valve or incorrect TPS voltage.
Here was Rodbolts advice on that thread...
here's what creates the 700 RPM or so idle.
mostly its by the temp sensor,TPS and ISC.
its possible the t-stat is stuck its possible the ISC is sticking or dirty and its possible the TPS voltage is incorrect.
the ECU will adjust air,via the ISC and ign timing based on signals from the ECT and TPS to try to maintain the ECU mapped idle speed for the throttle angle and engine temp inputs.
now ya just gotta find out whats not quite right.
remember the ECU is rather stupid.
  #3
Old April 29th, 2009, 02:16 PM
Default so is it something serious? or....
thanks cousinabe!!! so do you think my motor needs immediate attention by a mechanic? to tell you the truth, ISC, TPS, ECT.... i don't even know what the heck they are
  #4
Old April 29th, 2009, 02:41 PM
cousinabe's Avatar
I would get it serviced. make sure the tech has Yamaha fuel,electrical and 4 stroke certifications.
  #5
Old May 1st, 2009, 02:42 PM
gwseafarer gwseafarer is offline
fmmo, I had the same problem with my 03 f225 my 1st season. Rodbolt suggested I get it looked at since the motor was acting sick. It turned out to be the tps(throttle position sensor) was not set properly. No problems since getting it adjusted. A quick fix if done by a certified tech. Good luck and let us know what the problem was.
  #6
Old May 4th, 2009, 10:28 AM
Quote:
gwseafarer, thanks!!!!!!!! i'll definately have the TPS check by certified tech.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
F225 yamaha overheating for tuna Yamaha & Suzuki Outboards 1 April 27th, 2008 04:38 PM
Yamaha F225 Wenona Yamaha & Suzuki Outboards 2 January 5th, 2008 01:31 PM
Yamaha F225 2004 jack1 Yamaha & Suzuki Outboards 5 March 24th, 2006 05:27 PM
2002 Yamaha F225 mattttt25 Yamaha & Suzuki Outboards 8 April 6th, 2005 05:31 AM
Yamaha F225 squeak rustymed Yamaha & Suzuki Outboards 1 June 27th, 2004 08:09 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
