Re: mariner 115 starter stayes engauged
Disconnect the small yellow wire w/red trace line from the starter relay and retest.
That wire is the relay trigger, if the starter now remains off you have a short in the wiring somewhere.
If the starter continues to turn then the relay is shorted inside and needs to be replaced.
