thepotroast
- Feb 28, 2009
- 91
I did a quick search, and couldn't find anything that pointed exactly to my question (in the last couple of weeks), so figure I would ask.
What is the proper method of charging the starting and trolling batteries? More specifically...I have 2 deep cycle marine batteries. One is a cranking (Interstate), the other is for trolling (Everstart). I have a charger that does 2a/10/50a and has a switch for conventional and deep cycle batteries.
I normally charge deep cycles that are not in constant use, once per month at the 10a deep cycle setting until fully charged, and then before taking the boat out...I normally charge them up the night before.
However I read recently that you should put the batteries on charge when you bring the boat home....
What is the method to use to get the most life out of my batteries?
