doughboy19
- Mar 28, 2009
- 9
I have rebuilt the carbs, adjusted the floats, rebuilt the fuel pump, the reeds looked fine(from what I could see when cards were off), have 115 psi on all cylinders (4 cylinder), have great spark on all the new plugs, all wiring has been replaced, motor idles almost perfectly, no tach. When ran with ear muffs on shifts in to gear runs and revs fine. But when set in water dies after put in gear either direction. Throttle and shift cables have a little play in them. I have a manual on the motor, but need some help!???? Any ideals?
