  #1
Old April 28th, 2009, 03:58 PM
Reckless32 Reckless32 is offline
Default Avon hole and inflator valve repair?
I recently bought this older but really in great shape Avon 10.5' inflatable with the hardwood flooring. It's good for up to a 10hp motor I think, but came with a Nissan 2-stroke 5hp that runs great (though very slow).
Anyway the boat came with a known little leak on the port side basically right at the rigid rub rail looking stip down the side. Looks like it might have gotten gouged a little from a barnacle on a piling. The problem with patching it is that rub rail gets in the way of completely being able to slap a patch on it. Tried it once and it held for a few days beofre it started to leak again.
Is it okay to strip or cut away a portion of that strip to facilitate the patch, or no I'll make matters worse?
Also one of the inflator nozzles on the main port side tube is missing the rubber flapper portion that prevents air from escaping once you remove the foot pump. I have looked thru many websites including Avon and cannot find a replacement valve along the lines of simply screw out, screw in (if there is such a thing).
Where can I find (websites?) inflator valve replacement parts for this thing?
  #2
Old June 4th, 2009, 03:47 AM
Nos4r2's Avatar
Nos4r2 Nos4r2 is offline
Default Re: Avon hole and inflator valve repair?
It depends what valves you have in there-there's several types used on Avons.Try searching for:-
Avon A4
Avon A7
Avon C7
or if you're going to replace the whole valve,change the 'Avon' to 'Leafield' though you may have to import them from the UK.
It's fine to remove a portion of rubbing strake if you can do it without damaging the tube.However, you'll need to put sealant (sikaflex 291 or equivalent) along the leading edge of the removed portion to prevent lifting if your strake is in contact with the water at planing speeds.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Need valve plugs for ancient Avon Redseal Etaoin Shrdlu Inflatables and RIBs 1 November 9th, 2008 06:31 PM
Wish to purchase Avon rubber valve plugs Etaoin Shrdlu Inflatables and RIBs 1 August 5th, 2008 05:39 PM
Hole in my Valve cover NautiDog Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 July 21st, 2008 11:06 AM
Repair of RIB tubes valve stuag Boat Topics and Questions (not engine topics) 1 February 29th, 2008 01:54 PM
Hole on my valve cover sergioy Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 August 2nd, 2003 04:26 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
