Re: constant alarm 87 merc
Hello again. I checked compression and all 3 cylinders were fine. I cleaned the carbs and they were very dirty. Fired right up when I put the carbs back together, but not on the water yet. It is pumping water fine out of the tell tale. This engine has a water discharge above the top cylinder to the right as you look behind it. The hose is clear and there was no water going thru it. I believe this tube is for my gauge on the dash. The water gauge appears to be measuring water, but no water is going thru, bit once I disconnect this hose from the engine water jets out! But will not travel thru the line. Is air in the line blocking ot from reaching the gauge.
I also want to take off the lower unit and replace the impellar. My manual says take off the bolt facing the back of the stern. I have two bolts-in doing this will it then free the lower unit from coming apart? I took off the four main bolts and the bolt in the far back side of the lower unit. I last took off a lower unit on a 76 65 hp many years ago. I just received my manual and having a hard time with what unit is mine and which one isn't. Do I need to disconnect the shift linkage bolt that is tucked way underneath the motor under the cowling.
As always, thank you for your assistance. (it's starting to warm up in these parts!
