  #1
Old April 27th, 2009, 05:17 PM
black betty black betty is offline
Default 1998 Mariner 75HP alarm???????
i have a 1998 Mariner 75HP and when i went out last the alarm started going off but then it would shut up then start again but as it was goin off it sounded retarded like it was defective. it would change tones and stuff. so i would like to know how to test it and how to disconnect the oil injection to be on the safe side
  #2
Old April 27th, 2009, 09:00 PM
Default Re: 1998 Mariner 75HP alarm???????
HELP PLEASE!!! would like to work on tonight or tomarrow
  #3
Old May 1st, 2009, 08:02 AM
how do i disconnect oil injection and thje alarm so i can mix my gas????
  #4
Old November 17th, 2009, 05:07 AM
savage18 savage18 is offline
Quote:
Hi Black betty, did you find the problem with your alarm on engine as my 75 mariner is doing the exact same thing and sound after 15 mins of travel in water. thanks
  #5
Old November 18th, 2009, 01:13 PM
pops pops is offline
BB, the only oil alarm on your motor is just to detect low oil level in the tank. There is no alarm for an oil pump failure.
It is fairly common on older motors for the float to stick or sink which triggers the alarm. Disconnecting the sensor wire at the bottom of the oil tank will fix the alarm problem.
The really bad bottom line is that there is no way to tell if your motor has an oil pump failure until the motor sags while running. By then, it's probably too late!
  #6
Old November 18th, 2009, 03:12 PM
CharlieB CharlieB is offline
Check this parts view
http://www.mercruiserparts.com/Show_...n+C omponents
Remove the driven gear, item 18, the oil system no longer works.
Remove the tank and the lines to and from the pump, cap off all holes/hoses.
Religously pre-mix all fuel 50 : 1 with TCW-3 two stroke oil, remember to flush the lines to the motor AFTER mixing your fuel, the existing fuel in the line from the tank is straight fuel, no oil.
Done.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
91 Mariner 75HP Alarm Buzzer Warning horn issues marty53 Mercury & Mariner Outboards 3 June 17th, 2008 11:33 AM
Alarm....but it's not my fault? '95 Mariner 75hp hazemgt Mercury & Mariner Outboards 1 May 23rd, 2006 05:11 AM
Force 1998 75HP Help mburney Force & Chrysler Outboards 5 January 15th, 2006 04:44 AM
1998 75hp won't run Walleye Man Mercury & Mariner Outboards 1 May 29th, 2005 07:36 PM
75hp Mariner oil alarm AZO Mercury & Mariner Outboards 1 July 11th, 2003 09:50 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
