Re: Aluminum Boat Cleaning Question???
This is probably way out in left field, but I seem to recall reading somewhere that some sort of scale could be the result of galvanic corrosion, which is caused by aluminum coming into contact with another type of metal (such as brass) and the boat being used in salt water. The trick with tinnys is all fittings should be made of aluminum or stainless steel.
__________________
2008 Lund 1750 Fisherman
2008 Merc 115hp 4-stroke EFI
2008 Shorelandr' Trailer
And two wonderful golden retrievers
