matt88
- Mar 17, 2009
- 160
I have an older 30hp tohatsu that runs pretty good but on wot I have to pump the primer bulb periodically to keep plenty of fuel to the motor. I cleaned the fuel filter out and there were lots of gunk in the bottom. I havent had it back on the water yet but at idle on the water hose the primer bulb feels kinda firm but Im not exactly sure how firm it should be. I guess 80% of it was solid. Is this right or should I not be able to squeeze it at all? Another problem I had was the throttle screw is out of adjustment. Whats the best way to set this? I would think the best way would be on the water at wot but was wondering if there was an easier method,thanks
