  #1
Old April 26th, 2009, 11:05 AM
basspirate basspirate is offline
Default evinrude control cable replacement?
i bought a used 1980 evinrude 140. i just installed everything and the motor runs good except that the idle is a little high, about 250-300 over. i went back to the engine and pushed the throttle lever back aginst the block and the idle dropped but when i go to the control box and raise and lower the high idle lever the idle stays high again. is it time to replace the cables or is there something i'm missing.
  #2
Old April 26th, 2009, 11:24 AM
jay_merrill's Avatar
jay_merrill jay_merrill is offline
Default Re: evinrude control cable replacement?
There is a black wheel on the control cable at the engine end of it. It is the part that fits into the stainless steel retainer, ahead of the point where the cable fits onto the throttle gear or throttle arm, depending on what size engine you have.
Try adjusting this wheel to obtain proper idle speed. I would run the motor for awhile first, to make sure it is warmed up and able to idle without using the idle lever.
If you have to replace the cable, examine it to determine if it is the older Type 400 cable (set screw ends), or the newer Type 479 cable (press fit ends).
  #3
Old April 28th, 2009, 12:55 PM
thanks. it turns out i wasnt pre stretching the cables enough. although i may have to replace them anyway as i'm at the end of adjustment
  #4
Old May 12th, 2009, 09:59 PM
robertk robertk is offline
I have the exact same problem! What does pre-stretching mean and how is it done?
Thanks for your help.
  #5
Old May 12th, 2009, 10:26 PM
The wire portion of your cables is solid wire - there is no "prestretching" involved.
  #6
Old May 12th, 2009, 10:36 PM
Thanks - I will try the black wheel adjustment and see if that helps. The throttle control box and wheel adjustment seems so straight forward yet I can't seem to get it right. I'll try again this weekend.
  #7
Old May 14th, 2009, 09:19 AM
what i mean by prestretching is grab the black plastic slide that attaches to the throttle and give is a pull before attaching it to the throttle. it takes out the play in the cable and box. then adjust the cable before setting it in the holder. after it is in you can then finely adjust it
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
control cable replacement thefairlaneman Mercury & Mariner Outboards 1 May 14th, 2008 02:10 PM
Control cable replacement reelistic2650 Yamaha & Suzuki Outboards 4 September 5th, 2007 10:19 AM
Control cable replacement reelistic2650 Yamaha & Suzuki Outboards 3 August 29th, 2006 08:06 PM
Control cable replacement Realgun Force & Chrysler Outboards 1 March 28th, 2005 10:13 AM
Control Cable end replacement SCO Non-Repair Outboard Discussions 2 June 7th, 2002 04:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
