Is there a "rule of thumb" for how much longer a Mercruiser pre-Alpha throttle cable should be than the shift cable? Shift cable is on the transom plate and throttle cable below the carb.
I'm moving a 73 Mercruiser 140HP over to a different hull that's missing the shifter/cables and unsure how long the throttle cable needs to be, compared to the shift cable. I haven't installed the engine so I can't measure the length of throttle cable needed. Though, I was able to mock up the transom plate, old shifter and cables to figure out the length of the shift cable, 144".
The old throttle cable is 12" longer than the old shift cable, but the old cables had a lot of slop and droops so I don't trust getting a 12" longer throttle cable. My SWAG is that the throttle cable needs to be 18" longer,,, but that puts me half way between a 13 and 14' cable.
I guess if there is no "rule of thumb" I'll have to wait until the engine installed, but though I'd run it past the guru's.
BTW, I'm installing a Mercruiser 4000 GenII shifter (smoking deal) and ordering GenII shift cables.
