1975 e-rude 4hp
sdcoll
i recently acquired a 4hp evinrude model#4536A long shaft,i notice at the bottom of the gear casing that the extension adapter that makes it a long shaft is removable.i went on there parts list and notice that the extension has a bunch of parts also but my question is........whats needed to make it a short shaft?do i need extra parts to do this or simply just remove the extension that makes it a short shaft.another words is there a separate drive rod or does the extension just adds to that drive rod shaft to make it longer.......its a little hard to explain i guess...did anyone else do this?thankz for the help
Rick.
Re: 1975 e-rude 4hp
It's not all that clear on the parts site. Normally for other engines you would have to use a different drive shaft, exhaust housing, etc. Best thing would be to pull your leg and see but I think you will have to buy the parts not just remove the extension. Rick.
Vic.S
Re: 1975 e-rude 4hp
You'll need to remove the extension piece, shorten the water tube by 5" and replace the drive shaft with a standard length one. (318428 and $100 if its the standard drive not a weedless one)
Just possible for a good machine shop to shorten the existing shaft by 5" I suppose
sdcoll
Re: 1975 e-rude 4hp
wow 100 bucks huh oh well i guess it will have to stay long ....thankz guys
