Mercury 402: Can only turn flywheel with spark plugs out
I have a 1975 Mercury 402 SN: 42777XX. It's been in storage 2 years. The flywheel will only turn (either by the pull-start or by the startor motor) with the spark plugs out. Any ideas on what is wrong?
Re: Mercury 402: Can only turn flywheel with spark plugs out
Ed, Is it possible that the tips of the spark plugs are hitting the top of the piston?
You should verify that the plugs are the correct ones. A lot of mercs used the 1/2" reach, gapless plugs(like Champ L-76V) in the older motors. If someone put in some 3/4" reach, gap plugs you might have clearance issues.
Eat yer wheaties lad....
Like a snowmobile, good compression means lotsa armstrong starting. The sparkplug thing was a good thought, but if it turns over fine without plugs it should be fine.
If you can't turn it, it looks to me that it's stuck in gears. Maybe the shifter has slipped out of neutral. Can the prop be rotated freely in either directions?
Pull starter does NOT work with the plug IN?
But the pull starter does work with the plugs out?
I've seen many poor connections/starters/batterys have this problem but NEVER with a pull starter. Well, there was one just yesterday that I had to use BOTH hands, (I'm getting weak, I think).
If the pull starter works without the plugs, you (and I) maybe need to start working our arms a bit more to get in shape for fishing season.
With the plugs out, it will turn over, VERY difficultly with the pull start (and I'm not light in the arms). It is definitley more difficult than it should be, and no where near fast enough to fire up. With the electric starter (jumped via the boat battery wires to my truck's battery... truck running), it turns maybe once per second. I'm thinking poor electrical connections also (and will try jumping directly to the starter), except for the fact that it is so hard to pull with the pull starter.
Your original post stated that motor was stored for two years. Was it fogged before storage? Maybe try spraying some sea foam or 2 cycle oil in plug holes. Cylinder walls may be completely dry or worse...rusted.
Hi,
I don't mean to "piggyback " on your issue, but, I am having a similar(apparently compression) problem with a 1970 20hp. The motor turns over nice and easy out of water and wants to start but doesn't. If I put it in water it is next to impossible to pull. There was some debris thatg shot out of the exhaust ports under the powerhead and I could kind of see where some mud wasps had been in these same ports. Could this be the problem perhaps for both of us??
Not flogged, butI don't think piston binding on the cylinder wall is the problem. I turns fine with the plugs out. I pulled the carb, and the intake sideof the engine was nice and shiny. I'm thinking exhaust side might be plugged.
You said you overhauled the lower end. Did this problem start after that? The lower end is not that hard to take off, I would suggest that you drop the lower end and then see if the powerhead is free to turn over. Something is "bound up" and it is not a blocked exhaust or intake, you still have difficulty turning it over with the plugs removed, according to one of your posts. That leads me to believe the lower end may be the issue.
Quote:
Originally Posted by eldplanko
Lower unit was 4 years ago. Worked fine for 2 years after that.
Thanks for the good advice though.
Yes but then it sat for 2 years. If nothing else you should be changing the water pump impeller anyway, every 2 years is the norm. So, as long as you have the lower end off to change the water pump impeller you can check to see if it is any easier to turn the power head over. If not, you have work to do inside the power head.
Again, thanks all the advice, you guys are great.
This is where you mentioned that it was difficult to turn over with the plugs out as well.
I have the exact same problem!!! If i pull even just one plug it will turn over woth both the rip cord and the starter. It dosent matter what plug i pull it will turn freely and start. If i take out all plugs it spins freely and there dosent seem to be any problems with the cylinders. It is driving me up the wall. It wont even turn with my truck pushing the battery... I was going to replace the starter but then i remembered that the rip cord dosent work..Is there a pressure release valve?
Make up your mind. You said it pulls over very hard with the plugs out, now you say it turns fine.
With the plugs out, you should be able to turn it over very easily, especially fairly slowly. It should suck and puff through the spark plug holes. If it's binding, something is wrong, like a mouse nest in it, rusted cylinders, etc.
You should be able to peek in the cylinders through the spark plug holes. If that looks good, you may have rusted, siezed bearings.
It could be something under the flywheel, also. Magnets fell off and are binding or something like that.
Sorry for some confusion, above when I typed "with the plugs out" I meant "with the plugs in." That makes a big difference. I guess I just typed too fast.
I sprayed a bunch of PB blaster in the spark plug holes, let it sit a few weeks, sprayed some more and now it seems fine. I guess something inside was binding up, but got worked free.
