moreheadnc
- May 18, 2008
- 16
I own an 89 Evinrude 225, had the boat three years, have not replaced the water pump, the previous owner had not replaced it in the five years he owned it.
Took the boat to the local dealer to replace last spring, they could not get the lower unit off and wanted me to release them from responsibility if lower unit was damaged. Told them no way but asked them to test pump, tested fine. Ran boat all last summer.
Last week took the boat to the local 2-stroke guru to replace the pump and magnets in the flywheel. This guy is an older fella with a very clean and well equipped shop at his house and a yard full of nice boats and motors. He explained that the drive shaft is frozen in the power head and recommends cutting about 6" below the lower engine cover into the midsection approx. 2.5" to cut the driveshaft in half so he can remove the lower unit and also pull the powerhead so he can remove the shaft. Says he has done this a number of times, no problems. I am really sketchy about anybody cutting into my motor with a saws all. Have any of you encountered a frozen driveshaft holding your lower unit on? Any input is greatly appreciated on how it was handled. This pump has to be replaced, went fishing this morning and the rev limiter went off for the first time (didn't even know the motor had one)
