1.) Just discovered corrosion under the paint at the back of the lower unit, in front of the (removed) prop. How does this happen, and, is there a cathodic zink available to prevent this corrosion?
2.) Can someone point me to a maintenance manual for this trolling motor? I would like to open the lower unit, inspect, and replace anything necessary - especially the prop shaft seal.
3.) Any suggestions on what particularly to look for?
Any help appreciated.
Phil
Phil
