  #1
Old April 23rd, 2009, 10:14 AM
samm835 samm835 is offline
Send a message via AIM to samm835
Default 1992 115hp Mariner - Can you tilt without power?
If someone gets themselves into a situation where they need to tilt the motor up.....but doesn't have power to tilt it(yet), how can this be done or can it even be done? The motor does have tolt/trim, but it isn't completly hooked up yet, but the motor needs to be tilted to get into a workable position. Any help would be appreciated on this.
  #2
Old April 23rd, 2009, 11:19 AM
Chris1956 Chris1956 is offline
Default Re: 1992 115hp Mariner - Can you tilt without power?
There should be a manual release on the power trim unit. Usually on the lower part, and usually a large straight slotted plastic screw. Unscrew it and see if she tilts by hand.
  #3
Old April 23rd, 2009, 12:07 PM
I am not sure if I can even get to the tilt cylinder area, it was late last night and now I can't remember how close it is. But where would this release be? Does it just release the pressure or is it going to release the oil? Also is there a way to hook up a battery to the tilt wire and move it that way? I was reading some other post here, and I think if I read correctly that there are two wires, blue and green(under the cowl), it says disconnect the bullet connectors(not sure what that is), but if i connect the blue wire to a positive terminal that it should raise the tilt???? Anyone done this or know if it actually works?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1992 Johnson 115HP power trim question. Bansheex13 Johnson & Evinrude Outboards 1 July 26th, 2008 01:14 AM
1992 Mariner 115hp 98durango Non-Repair Outboard Discussions 2 July 2nd, 2005 06:10 PM
1992 Mariner 115hp 98durango Mercury & Mariner Outboards 1 June 5th, 2005 05:11 AM
1992 Yamaha 115HP will not tilt up! bans25 Yamaha & Suzuki Outboards 2 July 6th, 2003 07:46 AM
1992 Mariner 115hp Warning Module Failed BJM Mercury & Mariner Outboards 6 September 10th, 2002 06:43 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
