Okay, this is not a picture of MY boat, but I have the same exact one, with the exception of the nice deck plate access points on either side of the walk through transom, mine is solid floor on either side with NO way to get into that portion other than to cut out a spot for a new deckplate. So, my question is, would you
http://boats.iboats.com/cgi-bin/marine_classifieds/view_photos.cgi?ad_id=233102&img=4&count=2
I'm trying to also attatch a picture of my boat, not sure if it will work, either way the pics above provide more info.
1. cut a hole for a deckplate and get access to the vertical portion of the transom, then mount a kicker mount on the vertical portion of the transom through the fiberglass with a backing plate on the inside to act as a giant washer.
2. Mount "L" brackets on the horizontal portion of the deck so that the "L" points upward inline with there the transom turns down, then mount a board to the L brackets and hang your kicker.
3. do something totally different because I'm completely off???
Thanks for the help, been trying to figure this out for a while.
P.S. kicker is 61 pounds, honda 4 stroke.
