Re: Sea king problem
Broken drive shafts are unusual, and almost always are caused by a bent lower unit gearcase or exhaust housing. That puts the shaft out of alignment, causing it to bend back and forth with each turn. Yeah, I know, nobody believes you can bend the housings, but you can. Failure to tilt the motor when launching from a shallow ramp is one favorite way of doing it. Or backing into a stump. The OMC service manuals explain how to check them.
