  #1
Old April 22nd, 2009, 03:36 PM
basscats basscats is offline
Default 1987 115 inline six mariner lower unit
mine is a 1987 115 inline six mariner lower unit
will a 1989 150 lower unit fit my motor
  #2
Old April 22nd, 2009, 04:10 PM
emckelvy emckelvy is offline
Default Re: 1987 115 inline six mariner lower unit
No. A lower unit from a V6 definitely will not fit your Inline Six. Nor will a lower unit from any of the various Big Bore 3 and 4-cyl motors (circa '89 and up, with fiberglass 'clamshell' type engine covers).
You need a lower unit from another Inline six, vintage '79 or newer. Or from a 75-80 HP 66 C.I. Inline Four (older style with a wraparound cowling).
The '79-and-up 6-cyl L/U is an exact replacement for yours; the 4-cyl models have a different gear ratio (2.3:1 vice 2:1), and the only thing that will affect is the prop pitch if the Six rev's up too much with that gearbox. Simple matter of repropping with 2" more pitch.
Note, older Six and Four L/U's from '66 up may fit, but are not of the "improved" gearcase style. And if looking at an older L/U, shaft corrosion is a big issue due to carbon steel driveshafts (yours has stainless).
HTH..................ed
  #3
Old April 22nd, 2009, 09:58 PM
thanks for the answer
my first post
basscats
  #4
Old April 23rd, 2009, 01:01 PM
Chris1956 Chris1956 is offline
Ed, I am surprized that it won't fit. I was advised that my '77 Merc 1500 inline lower unit would fit my '93 135V6, with some simple modifications. it would seem logical that the reverse was true as well. Is his '87 Lu different from the '77 inline six LU?
  #5
Old April 24th, 2009, 12:59 AM
While the shift shaft location, front 2 studs position, water pump and driveshaft look eerily similar between the Inline and V6 gearcases, there are significant differences aft of there.
The V6 gearcase is quite a bit longer. Don't know if the spacing of the (2) studs underneath is the same, maybe someone with a V6 gearcase could do a bit of measuring. The exhaust tube area on the V6 is way bigger.
Here's another thought about swapping; the Inline gearcase likely wouldn't last long being torqued by a Mighty V6. Conversely, the V6 gearcase takes larger dia props and we all know Inlines don't like to swing those, eh!
I've posted a few poor quality eBay pics to illustrate the differences.
HTH............ed
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Merc 115 inline 6 water tube and lower unit probs Bob37814 Mercury & Mariner Outboards 3 August 16th, 2008 11:22 AM
1987 115 merc lower unit gottafish Mercury & Mariner Outboards 2 October 24th, 2007 09:43 PM
115 inline mariner lower unit nevermind Bob_VT Mercury & Mariner Outboards 1 July 16th, 2006 01:05 AM
inline 6 lower unit (merc 115) ayuh8 Mercury & Mariner Outboards 4 March 2nd, 2006 03:59 PM
1987 Mariner 115 inline 6 oil-injected? skidu Mercury & Mariner Outboards 5 July 12th, 2002 06:40 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
