need to find parts
bigunal
i have a trolling motor made by minnkota in mankato minn. serial #mkjj1371353 it is 40 lb thrust its called a power drive , the armature housing has 4 magnets in it and they are coming unglued , so its making a rubbing noise and scaring all the fish away and using to much battery power where do i go to buy the part i want:confused:
Silvertip
Re: need to find parts
What part do you want? Your choice is to replace the motor, or repair what you have. Clean the housing and epoxy the magnet back into the housing. If the magnet is broken, you will likely have to go to MinnKota to get it and don't be surprised if it is not a replaceable part. I take it you've already disassembled the motor and you are sure this is what the problem is.
