Hi All,
Bit of a newbie to this so apologies if my language is not to technical
I have an 70hp Evinrude Johnson outboard with original evinrude control box. When i move the lever into gear (forward) it is very hard to move. When you try and engage reverse it just won't move. Thought i might have a ceased cable so disconnected at outboard end and would you believe it control box lever moves free and easy!! thought the problem may be in the gear box but i can easily engage forward and reverse gears by pulling the rod that the cable attaches to. I'm totally bemused anybody got thoughts on what could be causing the problem.
hope that makes sense!!
Sheps2007
Sheps2007
