  #1
Old April 22nd, 2009, 02:02 AM
milatym milatym is offline
Default 1977 evinrude 70hp steering/cable problem
I recently purchased a boat with a 1977 evinrude 70 hp model # 70773S. The problem is that corrosion has locked up the shaft that the steering cable moves in order for the engine to turn. I need to get the whole assembly out and am most likely going to need replace the steering cable for it has come loose at the end of the shaft. Anyways, i was wondering if anybody on here knew of any tricks or ways to solve this problem as well as the parts i will need to replace the steering on the boat. The helm is good by the way, just the steering cable and the shaft assembly that slides through the engine. Thanks.
  #2
Old April 22nd, 2009, 05:09 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1977 evinrude 70hp steering/cable problem
PB Blaster, a block of wood, hammer, then a rod to drive it all the way thru. then you need to clean the rust out of the tilt tube. i recommend one of these and a drill.
http://www.iboats.com/T_R_Marine_Ste...-view_id.40162
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old April 22nd, 2009, 05:55 AM
F_R F_R is offline
Agree, beat it out the best way you can. Some of them can be extremely hard to get out...even impossible. Also, on many boats you have to lift the motor off the transom to make enough room to get it out. If that is the case, so be it.
Learn from it. Removing that cable and cleaning/relubricating it BEFORE it starts to rust is a regular preventative maintenance item.
  #4
Old April 22nd, 2009, 05:59 AM
Amen!!!!!!!!
__________________
FLORIDA GATORS
TEBOW Country
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1977 70hp Evinrude Power Problem eastowel Johnson & Evinrude Outboards 4 May 7th, 2007 12:48 PM
1977 Evinrude 70hp Starting Problem? jerwilson1 Johnson & Evinrude Outboards 2 May 30th, 2006 10:33 AM
1977 85hp Johnson steering cable is stuck and won't come out Fred Weston Johnson & Evinrude Outboards 6 November 14th, 2005 11:12 AM
1977 OMC out drive OEM steering cable. ajp Non-Repair Outboard Discussions 1 February 19th, 2002 10:37 AM
OMC Outdrive Steering Cable. 1977 style. ajp Boat Topics and Questions (not engine topics) 0 February 18th, 2002 10:53 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
