windsors03cobra
- Feb 22, 2009
- 1,191
Which octane for the Mercruiser 165hp Chevy 250ci ? I think its 8:1
Thanks
Thanks
The octane number and the lead in the fuel are two different issues completely.This will probaly open up a can of worms but I would not put 87 in my lawnmower much less my boat. The 250 straight 6 is a older motor which required leaded fuel.
Now I would ASSuMe you are not the orginal owner, so you don't know if the valves and seats have ever been redone to go with unleaded fuel.
If I did not know the answer I would either pull the head off and take it to a machine shop that rebuilds heads or I would buy lead substitute and 89 octane.
Car engines don't work half as hard as a boat engine.
My 2 cents.
Regarding lead and valve seats. If the engine does not have hardened valve seats, run the engine "as is" until you start losing compression due to seat failure. Why take the head off now when in all probability, it will last a long long time...possibly for as long as you own your boat.
