Mike Beals
- Mar 17, 2009
- 4
I am in the process of putting a 140hp mercruiser into a '69 ski boat, and can't get the splines to line up with the allignment tool. It seems as though the motor is sitting too high on the rear mounts. The mounts in the rear of the motor seem in good shape, and the fiber washers, and double wound lock washers were installed propperly. At best I can adjust the front mount so the tool is a tight fit, and when I pull it out and sight up the splines on the inside, the splines are too high toward the front of the motor. The only conclusion I can make is that the rear of the motor is too high, but I can't imagine worn mounts in the rear of a motor holding it too high. Anyone have some sage advice? Any help on this would be greatly appreciated.
