  #1
Old April 20th, 2009, 10:01 PM
joseph morales joseph morales is offline
Unhappy I need diagram for gauges
I just bought new century gauges and they didn't come with a wiring diagram, I need to know what wire is. I have blue,red,black, and purple there all on a plug in type connector, please help. Thank You
  #2
Old August 18th, 2009, 02:15 PM
Pez1704 Pez1704 is offline
Default Re: I need diagram for gauges
Quote:
Depends on the Century I guess... on my very old boat the purple wire is for the gauge lights... red and black should be hot & ground... I would imagine the blue is the sender, but it's hard to tell... I spoke with A&A marine in michigan and they were able to send me the schema for the entire boat, which ended up being mostly correct... correct enough to figure out the rest...
  #3
Old August 26th, 2009, 02:10 PM
In any case, you should be able to trace it out pretty easily... the hot wire will come off one of the ignition posts... the gauges' lights should come off the back of whatere switch turns them on... the ground is likely to be black... the other wire is the sender... Even if the ground isnt black, the lights get their ground of the gauge housing... so pull one of the wires off that you suspect my be the ground... if the light stops working you have found the ground... the other is the sender...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Gauges - I need gauges, where to buy nvr-enuf Non-Repair Outboard Discussions 2 June 5th, 2008 02:54 PM
Need wiring diagram for Yamaha control gauges ussdull Yamaha & Suzuki Outboards 1 June 13th, 2006 02:21 AM
Johnson 115 need help with gauges GatorMike Johnson & Evinrude Outboards 0 July 16th, 2005 06:34 PM
Help...I need new gauges for a Yamaha CLL2437 Yamaha & Suzuki Outboards 3 March 18th, 2005 04:31 AM
i need a wiring diagram or parts list diagram 72 100hp heyitswebb Johnson & Evinrude Outboards 5 August 27th, 2003 07:42 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
