  #1
Old April 19th, 2009, 10:35 PM
starkyb starkyb is offline
Default 1988 Mariner alarm
I have a 75 hp Mariner that I just purchased. I put it on the water for the first time yesterday and the throttle control beeps constantly from start up to wot. After reading prior posts it sounds like an oil or overheat alarm. The engine puts out a good stream of water and there is plenty of oil in the tank. There are 2 tan wires coming out of the bottom of the oil tank. Would disconnecting either or both stop the problem or is there something inside of the oil tank I should check first?
  #2
Old April 19th, 2009, 11:28 PM
Skeester45 Skeester45 is offline
Default Re: 1988 Mariner alarm
I have exactly the same motor and had the same problem. After determining that everything was working properly, I decided to simply disconnect those tan leads you mentioned that go to the oil level sensor. Beeping went away and all is well. This is a very common problem for our motor and is discussed in many forums. I would recommend adding oil to your fuel tank at 50:1 until you are sure the oil level sensor is the culprit. To test, simply disconnect those tan leads to the sensor while the motor is running and beeping. If the beeping quits, then its the sensor. The magnet attached to the oil level sensor float inside the tank is notorious for disconnecting itself and is the main issue. It cannot be repaired and you would have to replace the tank to fix it (or just run without a oil level sensor like I am). If the beeping does not stop, then it may be the warning module itself. Good luck, and let me know how it goes.
  #3
Old April 19th, 2009, 11:39 PM
Smile Re: 1988 Mariner alarm
Turned the key to the on position and it started beeping. I disconnected one of the wires wires and it stopped immediately. That was it! Thanks a bunch.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1988 Mariner 60 HP Overheat alarm fishinhardwater Mercury & Mariner Outboards 18 March 26th, 2009 10:15 AM
1988 88HPSPL Johnson heat alarm Doug Powell Johnson & Evinrude Outboards 6 September 8th, 2008 01:56 PM
1988 200XP engine alarm Walleye Man Johnson & Evinrude Outboards 3 June 17th, 2007 11:41 PM
1988 Mercury 70HP oil alarm?? NITRO150 Mercury & Mariner Outboards 2 July 10th, 2005 10:52 PM
Alarm - 1988 Mercury 175 Outboard jkering66 Non-Repair Outboard Discussions 2 August 5th, 2003 05:32 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
